1994 Chrysler LHS Idles Rough
1994 CHRYSLER LHS
KYDANTY
1994 Chrysler LHS 6 cyl Automatic 90000 miles
I just recently purchased a 1994 Chrysler LHS its runs good but idles rough. The timing belt and water pump have both been replaced. What could be causing it to idle rough? Another problem I have is that the gas gauge is off. When it says it has a quarter tank of gas it is actually empty, how easy would this problem be to fix. I am a single mom with very limited funds.
Aug 25, 2009 at 4:37 PM
  • 110,244 POSTS
Has the check engine light come on for the rough idle? Also, chances are the fuel pump float is bad. You need to replace the pump / float assembly in the fuel tank.
Sep 21, 2009 at 3:54 AM
