1994 Chrysler LHS idle control sensor
187,450 MILES • 6 CYL • FWD • AUTOMATIC
SISTAGIRL
where is the idle sensor located on this vehicle?
Jan 12, 2010 at 10:18 AM
CARADIODOC
  • 34,416 POSTS
What's the symptom? Do you mean the Idle Speed Motor? There is no sensor.
If the engine stalls at stop signs, and the battery was recently disconnected or run dead, you must relearn "minimum throttle" before the engine computer will know when to control idle speed.
caradiodoc
Jan 12, 2010 at 7:59 PM
