1994 Chrysler LHS Headlights
94,000 MILES • 4 CYL • FWD • AUTOMATIC
CHRISWILSON75
Tell me how to remove the front headlight so I can put another bulb in.
Oct 25, 2008 at 8:50 AM
CHRISWILSON75
[quote:27cd32c7c5="chriswilson75"]Electrical problem
1994 Chrysler LHS 4 cyl Front Wheel Drive Automatic 94000 miles
Tell me how to remove the front headlight so I can put another bulb in.[/quote:27cd32c7c5]
Oct 25, 2008 at 8:56 AM
IMPALASS
  • 3,112 POSTS
Hello
Well, believe it or not I have searched two vehicle data bases on your model and none of them explain or show pics of your lights. I have attached a pic for you – is this kind of what they look like?
I think you have a wire that holds the bulb in. If possible are you able to take a pic or two of the area and send them? I would be able to see and then possible talk you through if it what I think it is.
Oct 25, 2008 at 2:52 PM
WVMALE32
i have a 94 chrysler lhs also but mines a v-6 to change the headlights you need to remove the side markers then climb under the car there is a bolt thats holds it down it's on a bracket if you would shine a light up there while under the car you'll see it. and the headlight is attached to a arm so it only comes out so far but will leave you with enough room to change the bulb.
Apr 1, 2009 at 2:18 PM
