1994 Chrysler LHS carbon on plugs passenger side only
1994 CHRYSLER LHS
2CHEAP
Engine Performance problem
1994 Chrysler LHS 6 cyl Front Wheel Drive Automatic
after removing my lifetime plugs only the passenger side where heavily carbon up . change pcv value & new hose new plugs ,i pulled the plugs to test & the passenger side again was carbon up mpg is bad
Aug 21, 2010 at 5:22 AM
DOCFIXIT
  • 18,828 POSTS
Pull vacuum line off fuel pressure regulator see if fuel is present. If yes replace regulator
Aug 21, 2010 at 6:03 AM
