1994 Chrysler LHS brakes are squeaking
BRITT07
Brakes problem
1994 Chrysler LHS Engine Size unknown Wheel Drive Type unknown Automatic 134569 miles
the brakes are starting to squeak really bad and im not sure what i should do. should i gt brake pads or new brakes or rotos?
Dec 14, 2007 at 4:40 AM
CARLUCCIJA
  • 29 POSTS
First thing to do is to check you break pads for wear. If the breaks are old most likely they need to be changed, but don't over look those rotors. Check those for warpage and cracks. If those are bad i would replace breaks and rotors.
Dec 18, 2007 at 7:48 AM
