1994 Chrysler LHS
1994 CHRYSLER LHS
156,060 MILES • 6 CYL • FWD • AUTOMATIC
VMPYRS
  • 7 POSTS
how do you replace the headlights and remove the lence
Mar 21, 2010 at 11:24 PM
CH112063
  • 1,320 POSTS
From behind is a locking ring that comes off by unscrewing it. Then the socket with the small halogen lamp comes out, the replacement has a new socket. The connector has a plastic locking clip you must pull up to take the connector off. The lens is a lifetime unit that needs to be adjusted with a professional beam adjuster if removed. But taking the plastic body trim off first(torx screws T-20) gives you access to the lens mounting to replace just the lens.
Mar 24, 2010 at 10:32 PM
