1993 Chrysler LHS
160,000 MILES • 6 CYL • 2WD • AUTOMATIC
ISAAC6428
THIS CAR TURN ON FOR ABAUT 3 SECONDS AND TURN OFF TURN ON AGAIN Y JUST FOR 3 SECOND AND TURN OF I TRY WIHT ALARM CONTROL AND UNLACK THE DOR WITH THE KEY BUT NO WORK DO YOU THIK THE PROBLEM IS THE ANTITHEFT MODULE? IF REPLACE NEED REPROGRAM THE KEY?
Feb 20, 2009 at 4:06 AM
  • 110,251 POSTS
Hi:
Is the security light staying on? If not, I recommend checking fuel pump pressure. Many parts stores will lend or rent the gauge. Here is a how to video:
https://www.2carpros.com/dia/test_fuel_pressure.htm
Let me know what you find.
joe
Feb 21, 2009 at 11:47 AM
