1992 Chrysler LHS broken
120,000 MILES • 6 CYL • FWD • AUTOMATIC
CONERTMUST
drivrt side rear wheel is about to fall off the car.its not lug nuts that part is fine.is there a inside axel bearing,or somethang.thank cripeld car.
May 28, 2008 at 2:30 PM
LEGITIMATE007
  • 5,121 POSTS
yeah thats more than likely your bearing assemply , its probably shot, someone is gonna have to pull the tire off and check the drum, if its rotors in the back then its the wheel assembly, but I think its drums. pull the tire off and buy new bearings and repack it.
May 28, 2008 at 3:15 PM
