What does the trouble code mean
CHRYSLER LE BARON
TMWSHO
I have a 91 lebaron convertable v.6. It has been parked for about 4 years and when we started it up it ran fine for a few days then it started acting like it was out of gas but when you restart it it runs fine for a few minutes and then chugs like it is out of gas. I pulled the fault codes and the code that pulls up is 51 Lean air/fuel mixturehas been indicated by an abnormallyrich correction factor. What does this mean and what do I do.
Oct 15, 2007 at 9:40 PM
BMRFIXIT
  • 19,053 POSTS
[quote:a9b8ed8970="tmwsho"]I have a 91 lebaron convertable v.6. It has been parked for about 4 years and when we started it up it ran fine for a few days then it started acting like it was out of gas but when you restart it it runs fine for a few minutes and then chugs like it is out of gas. I pulled the fault codes and the code that pulls up is 51 Lean air/fuel mixturehas been indicated by an abnormallyrich correction factor. What does this mean and what do I do.[/quote:a9b8ed8970]
check and or look for
low fuel pressure
vaccum leak
and check the o2 sensor connection
good luck
Nov 17, 2007 at 5:08 PM
