1992 Chrysler Le Baron help with code 37
1992 CHRYSLER LE BARON
170,028 MILES • 6 CYL • 2WD • AUTOMATIC
ROMICOLE
I'm not getting any gas to my engine at all. It cranks just fine. I have a half a tank of gas. It has been sputtering in the past. A lose of power while on the road at times. Now it just won't turn over. I bought a fuel relay and an asd but first I ran the codes and came up with 12..37..55. Called napa where I got the relays and asked them have they heard of an throttle body unlock solenoid. They told me that's my problem. My question is first..where is it and could this really be it ...for 26 bucks lol
thanks
romi
Sep 23, 2010 at 2:51 PM
Chrysler
11 Engine has not been cranked since battery was disconnected.
12 Memory Standby power lost.
13 MAP sensor pneumatic circuit.
14 MAP sensor electrical circuit.
15 Vehicle speed/distance sensor.
16 Loss of battery voltage sense.
17 Engine running too cool.
21 Oxygen sensor circuit.
22 Coolant temperature sensor circuit.
23 Throttle body temperature sensor circuit.
24 Throttle position sensor.
25 AIS motor driven circuit.
26 Peak injector current not reached.
27 Fault in injector driver interface circuit.
31 Purge solenoid circuit.
32 On Calif. models, EGR diagnosis.
33 A/C cutout relay circuit.
34 Speed control solenoid driver circuit.
35 Fan control relay circuit.
37 Fault in part throttle unlock solenoid driver circuit.
41 Charging system excess or no field circuit.
42 ASD relay circuit.
43 Fault in ignition coil control circuit.
44 Loss of FJ2 to logic board.
46 Battery voltage too high.
47 Battery voltage too low.
51 Oxygen feedback system stuck at lean position.
52 Oxygen feedback system stuck at rich position.
53 Internal logic module problems.
54 Indicates a fault in the distributor high data rate pickup circuit.
55 Completion of fault code display.
62 Indicates unsuccessful attempt to update EMR mileage.
63 Unsuccessful attempt to write to an EEPROM location by the controller.
77 Speed control power relay circuit.
Check for spark and fuel, do below
Get a helper disconnect a sparkplug wire or 2 and ground it to the engine at least 3/16 away from ground -have helper crank engine over-do you have a snapping blue spark? If so-you have a fuel related problem, check the fuel pressure to rule out the fuel filter/fuel pump/pressure regulator and listen to the injector/s are they pulsing or hook up a noid light. No snapping blue spark continue to troubleshoot the ignition system-power input to the coil/COP/coil packs,coil's resistances,distributor pick-up coil, ignition control module, cam and crank sensors and computer Note: If it doesn't apply disregard it.
Sep 24, 2010 at 6:12 AM
