1989 Chrysler LeBaron Hard Turning
SLOFING
  • 21 POSTS
I have a 1989 Turbo 2.5 convertible with 15 inch factory wheels. It is an automatic.
The problem is the car has horrible turning, it wont turn sharp, only wide. It sometimes takes 2 tries to turn into the driveway. It is also very stiff. There is no play or shimmy in the steering. I am not the original owner and wonder if someone put the wrong rack and pinion or if it is somehow damaged. Have you ever seen this problem before?
Jul 27, 2007 at 5:13 PM
2CARPRO JACK
  • 11,533 POSTS
Could be the wrong rack in it. Hard to turn like low/no power assist? Do the wheels turn until they hit the steering stops?
Jul 28, 2007 at 1:54 AM
SLOFING
  • 21 POSTS
[quote:c77e5b28b2="2CarPro Jack"]Could be the wrong rack in it. Hard to turn like low/no power assist? Do the wheels turn until they hit the steering stops?[/quote:c77e5b28b2]
There are no typical steering stops like iv'e seen on the lower control arms in the past. One more interesting thing is the steering whell only turns 2 times not the typical 2.6 turns i found in the specs online. I have clearance in the wheelwell to turn farther.
Jul 28, 2007 at 9:29 AM
2CARPRO JACK
  • 11,533 POSTS
Sounds like it could be the wrong rack and pinion
Jul 30, 2007 at 12:42 AM
Suggested Repair
Inspect the rack and pinion and replace it if it is the wrong unit for this vehicle. Limited lock-to-lock travel and stiff, wide turning point to an incorrect or damaged rack.
Conversation Summary
The owner of a 1989 Chrysler LeBaron Turbo convertible reports stiff steering and an excessively wide turning radius, with no play or shimmy. The steering wheel turns only about two times instead of the specified 2.6, and there is wheel-well clearance to turn farther. The expert says the vehicle may have the wrong rack and pinion.
