how do i fix a sagging door on a 1988 chrysler lebaron convertible?
Nov 28, 2007 at 6:19 AM
With the door open, check whether it rocks up and down. If it does, the hinges are worn and should be replaced.
The owner asked how to fix a sagging door on a 1988 Chrysler LeBaron convertible. The expert advised checking whether the open door rocks up and down; if it does, the worn hinges need replacement.
