1991 Chrysler LeBaron Stalls at Stops
HANNAHG
1991 Chrysler Le Baron: v6: 100,000 miles
Hello: I recently had a friend replace my water pump & when I picked up my car, I noticed that it was idelling poorly. At first, it would die every time I stopped at a stop light, got off the highway or hit the brake. I replaced the battery b/c I read on-line that this could be an issue, and it helped. However, the car still dies at stop lights and is not running like it did before. If I put the car in neutral, then it won't die at stop lights. I was wondering if you had any idea what is wrong with it? I'm 99% sure that he did something when he was repairing it b/c he had a very hard time with the repair.
Thanks so much for you time :)
Mar 17, 2007 at 1:29 PM
  • 75,988 POSTS
[quote:3cf7ac0eed="hannahg"]1991 Chrysler Le Baron: v6: 100,000 miles
Inspect and test the PCV valve and the EGR system for a start we still got a long way to go and then comeback.
Thanks so much for you time :)[/quote:3cf7ac0eed]
Mar 17, 2007 at 6:56 PM
MAYNARD G
  • 5 POSTS
I would recheck camshaft alignment 1 cam can be off 1 tooth. there are check ports on the timing cover so you don't have to pull things back apart. 1 tooth on 1 cam can cause this problem. i have had this problem before on 90 lebaron 3.0
manard g
Mar 25, 2007 at 2:51 PM
Suggested Repair
Recheck camshaft timing alignment, since one cam may be off by a tooth and the timing cover has check ports. Also inspect and test the PCV valve and EGR system.
Conversation Summary
A 1991 Chrysler LeBaron began idling poorly and stalling at stops, when braking, or after highway driving following a difficult water pump replacement. A new battery helped somewhat, and the engine stays running in neutral. Experts advised checking the PCV valve and EGR system and rechecking camshaft alignment, noting that one cam off by a tooth can cause this stalling.
