1996 Chrysler Le Baron Will not start
BRASSNOB
Engine Mechanical problem
1996 Chrysler Le Baron 6 cyl Front Wheel Drive Automatic 130K miles
Battery checked out as good but the starter will not turn over.
Sep 12, 2008 at 7:17 AM
BMRFIXIT
  • 19,053 POSTS
check the starter
can u jump it and does it crank if u jump the terminals on the starter (key off)
I would suspect starter
check the S small terminal wire and connector
check fuses and starter relay
Sep 12, 2008 at 7:24 AM
