1995 Chrysler Le Baron Rumbles
105,000 MILES • 6 CYL • 2WD • AUTOMATIC
DGALARDI
Car makes a rumbing noise similer to the older trucks that used bias belted tires. Everything seems tight in the wheel. One unusual thing that happens is that while drived and goin through right bend in the highway,the noise goes away. the rumbling resumes when driving straight. Appreciate any help with this.
Mar 10, 2009 at 10:52 AM
  • 110,248 POSTS
It sounds like a bad wheel bearing on the right side of the car. If the tires are smooth and not chopped, check the bearings. One will be bad (front or rear).
Let me know what you find.
Mar 17, 2009 at 1:35 AM
