1995 Chrysler Le Baron oil pressure gauge issue
76,500 MILES • 6 CYL • FWD • AUTOMATIC
JAMMINFOOL
The oil pressure gauge in my wife's '95 LeBaron GXC is reading max pressure (Hign, or the "H" on the gauge). The car is only driven occasionally, and the oil was changed before it was stored last. There are no odd noises or smells coming from the engine, nor is there any smoke coming from the exhaust. Should I be concerned about this?
May 25, 2010 at 6:46 AM
  • 75,988 POSTS
Check the oil pressure with a mechanical gauge if normal replace the oil pressure switch abnormal could mean the oil pump pressure relief valve is stuck closed
May 25, 2010 at 11:44 AM
