1995 Chrysler Le Baron No Fuel
146,513 MILES • 6 CYL • FWD • AUTOMATIC
CRAZYSYRUP1987
Its a 95 lebaron with the 3.0 sohc. The Car wont start. I have compression and spark. Checked the timing it is dead on. Hooked up a noid light to injector 6 and found that i have no signal... any ideas?
Mar 21, 2010 at 1:26 PM
  • 75,988 POSTS
Could be no power to the injectors or the computer ground drivers
Mar 21, 2010 at 2:10 PM
CRAZYSYRUP1987
should i have power to the common wire between all the injectors or should it be constant ground with the individual wires from the pcm supplying the positive?
Mar 21, 2010 at 4:59 PM
  • 75,988 POSTS
You should have power on the dark green and orange wire on all the injector the other color wires on the injector is the grounding wires to the computer
Mar 21, 2010 at 5:12 PM
CRAZYSYRUP1987
I'll test it out thanks for your advise... I'll let you know how it goes later today
Mar 22, 2010 at 1:52 AM
