1995 Chrysler Le Baron My engine overheats and my radiator
120,000 MILES • 6 CYL • FWD • AUTOMATIC
LEBARONLUV
Ok. I just got a 95 Chrysler LeBaron GTC convertible and I've been having a major problem! The lower radiator hose was once leaking but I got that replaced. I thought that was the problem but obviously it wasn't. Now as I watch my car in a idle position nothing leaks but once I take off you can see its leaking from whatever the lower radiator hose is hooked up to. When I got the car the manual wasn't included so I've been having trouble finding what the lower radiator hose is hooked to because that is where its leaking really bad. Do you have any idea what that might be or what is causing my fluid to leak? I also checked my oil and there is no water mixed with it so it can't be a blown head gasket.
Oct 24, 2008 at 4:58 AM
  • 110,248 POSTS
It is attached to the water pump. It will need replaced.
joe
Mar 17, 2009 at 3:48 AM
