1995 Chrysler Le Baron 6 cyl Front Wheel Drive Automatic
leking water when engine is on
May 21, 2009 at 2:32 PM
LEGITIMATE007
✓Experienced Mechanic
what area,? it could be at the water pump, heater hoses, what area is it leaking
May 21, 2009 at 2:41 PM
CHRISTIAN327
MEMBER
its leaking under the car everywhere for about a year I drove with water jugs filling the car up every time i was going it would last untl one day it got hot and water leaking underneatrh the car and wont hold water
May 21, 2009 at 2:48 PM
LEGITIMATE007
It sounds like it is comming from a freeze plug, the way your describing it. Its still a little vague , the way you describe it. because it could be leaking from the rear and just trickle down the back and appear to look like its comming from the bottom
