1995 Chrysler Le Baron hesitation
1995 CHRYSLER LE BARON
129,000 MILES • 6 CYL • FWD • AUTOMATIC
FRANKSMALL
I replaced the TPS.
(the car will stall when pressing on the gas pedal normal.)
if I press hard on the gas pedal the tires spin and runs ok
if I press real slow on the gas pedal the car runs ok.
what would cause this or what should I do to correct this problem to drive normal.
Thanks Frank
Oct 14, 2010 at 1:56 AM
Do you have a check engine light and when was the last tune-up??
Could be one of the following below:
Oxygen sensor.
Catalytic converter.
Fuel injectors dirty/sticking.
Throttle position sensor.
Manifold absolute pressure sensor.
EGR Valve
Fuel pressure regulator leaking or defective fuel pump.
False air leakage.
Fuel contamination.
Foul/defective spark plugs.
Open spark plug wires.
Ignition coil/Coil packs defective.
Incorrect ignition timing.
Cap and rotor.
Oct 14, 2010 at 4:22 AM
PLOPPYSATOR
  • 23 POSTS
(corrected:)
It is either the MAP sensor (or its contacts) or the tubes to/from it are leaky.
Oct 19, 2010 at 7:36 PM
In my proposals I did mentioned the MAP sensor and false air leakage is it any different than your suspicions
Oct 19, 2010 at 10:51 PM
PLOPPYSATOR
  • 23 POSTS
[quote:af6a1f2989="rasmataz"]In my proposals I did mentioned the MAP sensor and false air leakage is it any different than your suspicions[/quote:af6a1f2989]
Pardon me, please, U are absolutely right!
Oct 20, 2010 at 1:24 AM
