1995 Chrysler Le Baron help
1995 CHRYSLER LE BARON
ARCHER787
Engine Performance problem
1995 Chrysler Le Baron 6 cyl Front Wheel Drive Automatic
i have a 1995 labaron gtc it jumps when pulling slow...and if u floor it pulling out at 4000 rpm it jumps like a bronco can u help
May 10, 2010 at 12:23 PM
Lack of acceleration,chugging,hesitating,bogging etc. could be caused by one of the following below.
Inspect and test all the following listed below and get back with some results
Oxygen sensor.
Catalytic converter.
Fuel injectors dirty/sticking.
Mass airflow sensor/Airflow meter.
Throttle position sensor.
Manifold absolute pressure sensor.
EGR Valve
Fuel pressure regulator leaking or defective fuel pump.
False air leakage.
Fuel contamination.
Foul/defective spark plugs.
Open spark plug wires.
Ignition coil/Coil packs defective.
Incorrect ignition timing.
Cap and rotor.
Note:If it doesn't apply disregard.
May 10, 2010 at 1:59 PM
