1995 Chrysler Le Baron fluid on driver side floor
28,674 MILES • 6 CYL • FWD • AUTOMATIC
SUZANNE63
i think i am leaking radiator fluid onto the driver side floor.
what would be the cause and how can it be fixed or repaired..
thank you in advance.
suzanne
Dec 18, 2007 at 3:02 PM
  • 31,937 POSTS
Hi there,
If you are leaking coolant in side the car, it will be coming from the heater core, Have the system pressure tested to prove the leak, keep your coolant topped up, normal practice is to replace the heater core, as i am unfamiliar with this car, your mechanic will be able to advise you.
Mark (mhpautos) Australia.
Dec 18, 2007 at 5:11 PM
