1995 Chrysler Le Baron Bleed hydraulic lines for convertibl
1995 CHRYSLER LE BARON
178,000 MILES • 4 CYL • 2WD • AUTOMATIC
RAND1B
I just replaced the brushes in the convertible top motor and while it was disconnected the top was put up then down. I need to bleed the lines.
Jul 8, 2009 at 8:41 AM
BILLYMAC
  • 2,204 POSTS
crack the lines and run the pump.
put a suitable container under and wrap a shop towel around the lines to prevent fluid spray. when bled the top will start to raise. tighten lines and work op up and down a cpl times..
Billymac
Aug 9, 2009 at 2:16 PM
