1995 Chrysler Le Baron
LJAY51
  • 1995 CHRYSLER LE BARON
Computer problem
1995 Chrysler Le Baron 6 cyl Two Wheel Drive Automatic
what does it mean on my dash deck a jar
Monday, August 17th, 2009 AT 10:15 PM
CH112063
  • 1,320 POSTS
It means that your deck lid (trunk, hatch) is open. A switch closes a circuit when you open or unlatch the decklid. If you know it is closed you can disconnect the switch usually on the latch and it just won't work. I don't think your check engine lamp will come on. Remember that you must insulate the disconnected wiring.
Beautiful car. Good luck. I'm suprised it hasn't already been disabled. I think it's safer to replace it. Watch you don't blow a fuse by accident.
Wednesday, August 26th, 2009 AT 7:20 PM
