The passenger-side door window motor has died, due to water getting past the weather stripping (inside plastic was resting on top of motor has rust on it). My question is this...is there a way to manually raise the window, until I can have the motor replaced. I've tried to lift it, while having someone press the "up" button, but it won't budge. I do have a good electrical connection, as I can hear it "try" to function when the button is pressed.
Nov 5, 2008 at 10:20 PM
