1994 Chrysler Le Baron Shaking badly when on interstate &am
120,192 MILES • 6 CYL • FWD • AUTOMATIC
CRISSIE7789
I own a 1994 Chrysler LeBaron GTC, 6 cyl. I have had the car about two and a half years and have never had much of a problem with the handling UNTIL NOW!! I recently went and had my tires rotated and balanced, and now I am having some major handling issues, at first it was pulling back and forth and was so scarry to take on the interstate that I almost screamed. So I took it back to another tire shop and had them take a once over on it for the 2nd time in 2 days. They did cure it pulling from side to side badly but it still shakes rather badly when I am on the interstate. The 2nd tire repair shop told me there was some mud/dirt on the inside of the front tire/rims and that was causing some of it - got the rims/tires cleaned out and balanced it for me. How i knew it was to good to be true is beyond me - now 75 dollars later I am stuck not being comfortable to take it back on the interstate until the issue is resolved not wanting to cause any other issues. What do you suggest I check into as the cause now? I really thought it needed to be realligned but after mechanic road tested the car they said it was fine just balancing tires. I AM NOT CASH WEALTHY AND JUST NEED TO ADDRESS THE ISSUE HOW DO i NARROW DOWN THE PROBLEM
Mar 15, 2008 at 5:23 AM
CHRIST1G
Have you found the problem yet? If not be sure to have the trans motor mount checked
Oct 9, 2008 at 5:55 AM
SCOOBZBOX
I own this same car. I also have this exact same problem, although, I haven't experienced the failing repair issue, cuz I haven't yet taken it in to be fixed. Upon acceleration, the car pulls to the right, if I accelerate too fast. The wobble and shimmy IS very scary, but once I'm up to speed, it drives relatively smooth. I have been told by my tire guy that it is probably the tranny mount. I've also been told that the front motor mount is bad. I love this car, but honestly, it seems to be heading into issues that I dred. I am considering unloading it before it has too many problems and renders it unsellable. I can't afford a car that is a money pit. Have you had any luck with solving the motor mount "refailing" issue?
Nov 5, 2008 at 10:42 PM
