1994 Chrysler Le Baron Serpentine Belt
152,000 MILES • 6 CYL • 2WD • AUTOMATIC
CLPDIVER88
When I was driving down the freeway...I hit a puddle and my serpentine/alternator belt slipped off and I know the routing thanks to your diagram:) and I know that you can loosen the tension by turning counter clockwise on the drive belt tensioner but there is not a 1/2 square opening....I have a bolt thats bigger than 1/2" but smaller than a 9/16"....so how do I get my belt back on???
Dec 15, 2008 at 8:22 AM
OBXAUTOMEDIC
  • 3,711 POSTS
[quote:a001dbb97f="clpdiver88"]Engine Mechanical problem
1994 Chrysler Le Baron 6 cyl Two Wheel Drive Automatic 152000 miles
When I was driving down the freeway...I hit a puddle and my serpentine/alternator belt slipped off and I know the routing thanks to your diagram:) and I know that you can loosen the tension by turning counter clockwise on the drive belt tensioner but there is not a 1/2 square opening....I have a bolt thats bigger than 1/2" but smaller than a 9/16"....so how do I get my belt back on???[/quote:a001dbb97f]
The Bolt Size is if I am not mistaken a 13 mm. The bolt you are speaking of is in the middle of the tensioner pulley..... you can use that bolt to loosen the tensioner.....
Dec 15, 2008 at 8:28 AM
