1994 Chrysler Le Baron Runs bad
126,000 MILES • 6 CYL • FWD • AUTOMATIC
BATT49
When I start it in the morning. It idles fast then down to nothing. Then fast and down to nothing. And it sometimes dies. Then it levels out and idles ok. Then when I go to drive it, it is sluggish and doesn't want to run. I had the injectors cleaned. And it ran good for about 2weeks. now it is back to running sluggish again.
Thank you for your help.
Tim
Dec 26, 2007 at 4:42 AM
LEGITIMATE007
  • 5,121 POSTS
get yourself a can of throttle body cleaner and follow the instructions. this will sometimes do miracles. You may have a lot of carbon build up on the throttle plate and egr valve.
Dec 26, 2007 at 5:20 AM
