1994 Chrysler Le Baron Lights issue
11,200 MILES • 6 CYL • FWD • AUTOMATIC
BH-IL
First time user.
My 94 Lebaron GTC Convertible has a problem with the lights. With light switch on, no dash lights, no taillights and the windshield wipers come on. When you turn the switch off, the wipers stop and the headlights stay on, until I pull the 40A fuse in the engine bay. The wipers work correctly off of the wiper switch, and the taillights and flashers and brake lights work OK. Everything else works fine on the car. I have replaced a few fuses and the battery since I got the car. I pulled the body computer behind the passenger kick plate and sprayed the contacts with contact cleaner, and they look good. No difference after that. When the body computer is out the headlights work correctly and the wipers do not come on. But still no dash lights and no taillights.
Any help appreciated. First time user.
May 13, 2010 at 2:32 PM
PLOPPYSATOR
  • 23 POSTS
It seems, I have a similar problem with my '93 LeBaron
Oct 19, 2010 at 8:21 PM
