1994 Chrysler Le Baron leak wet carpet
106,684 MILES • 6 CYL • FWD • AUTOMATIC
HDTURRENTINE
Had windshield replaced and then started noticing soaked carpet under drivers foot area. Window company checked and said windshield not leaking. Can't find water source.
Also need to find new convertible top weatherstripping as top company cut old one causing a wind tunnel effect while driving.
Mar 2, 2009 at 3:13 AM
  • 110,246 POSTS
If the leak started after the windshield replacement, I would start there. Have someone spray the front of the car with a hose. Using a flashlight, check under the dash for evidence of leaks.
As far as the top, start with the dealer.
Mar 17, 2009 at 1:40 AM
