I need help to find out where the fuel pump is and is it easy to remove if i dont know how to do it. I need to put in a new on ei just bought
Aug 28, 2009 at 6:18 AM
BLUELIGHTNIN6
✓Experienced Mechanic
fuel pump is located inside of fuel tank. you should have an access panel in the trunk, underneath the liner. remove the panel and disconnect wiring and fuel hoses. remove the hose from rollover valve. loosen fuel pump band clamp and remove pump.
Aug 28, 2009 at 2:27 PM
MASAKIS88
MEMBER
I was told it was right buy the tire just take the tire off and it right there buy fuel tank
Aug 28, 2009 at 6:05 PM
BLUELIGHTNIN6
which model of Le Baron is your vehicle.?
Aug 28, 2009 at 6:14 PM
MASAKIS88
MEMBER
Could u msn messenger me it would be faster my msn is masaki1688@msn.com
But i believe its a lx. i no its a 3.0 v6
