1993 Chrysler Le Baron Wheel Cylinder Repair Kit
58,000 MILES • 6 CYL • 2WD • AUTOMATIC
PHILIPSCAIFE
I bought a wheel cylinder repair kit from auto zone part no. 66535 wich was supposed to be for my vehicle but on dismantleing found the rubber parts were only half the size of mine. Please could you help with a specific part no.?
May 10, 2010 at 1:12 PM
BLUELIGHTNIN6
  • 16,542 POSTS
do you have the sedan or the coupe / convertible ? check to see if the rubber piece is 5 / 8" in diameter.
May 10, 2010 at 3:41 PM
PHILIPSCAIFE
[quote:19fb6b02e3="philipscaife@windstream.n"]Brakes problem
1993 Chrysler Le Baron 6 cyl Two Wheel Drive Automatic 58000 miles
I bought a wheel cylinder repair kit from auto zone part no. 66535 wich was supposed to be for my vehicle but on dismantleing found the rubber parts were only half the size of mine. Please could you help with a specific part no.?[/quote:19fb6b02e3]
Convertible
May 11, 2010 at 12:06 AM
BLUELIGHTNIN6
  • 16,542 POSTS
your vehicle's wheel cylinder should be .625" (aka 5/8") . that is what is listed by the manufacturer as well as all of the auto part stores I have looked at. I'm not sure why yours would be larger than that unless someone has changed the brake system on it.
May 11, 2010 at 5:01 AM
PHILIPSCAIFE
[quote:5a3873adf4="bluelightnin6"]your vehicle's wheel cylinder should be .625" (aka 5/8") . that is what is listed by the manufacturer as well as all of the auto part stores I have looked at. I'm not sure why yours would be larger than that unless someone has changed the brake system on it.[/quote:5a3873adf4]
Thank you, I think I will replace the wheel cylinders instead of using the repair kit.
May 11, 2010 at 1:58 PM
