1993 Chrysler Le Baron transmission shifting problem
KSENDSLEY
Transmission problem
1993 Chrysler Le Baron 6 cyl Front Wheel Drive Automatic
hi all. i have already donated money with this same question 7 days ago, and have not received an answer yet, so i will post it again.
when the car is cold (first start of the day), after starting and placing into drive it takes a few seconds before it shifts. reverse is always availible and shifts smooth. after the car does shift into drive, it goes into limp mode. when i turn the car off and back on, all shifting is normal, smooth. when its been driven and sits for about an hour, it can take up to 2 minutes or more until it shifts into drive. again shutdown and restart all is perfect. i have replaced the filter and fluid to no avail. can someone please help me?
Apr 7, 2010 at 7:18 PM
PLOPPYSATOR
  • 23 POSTS
Clean your solenoid or replace it (and check, if there is the correct ATF+III transmission oil in it and if the oil filter is not blocked). What oil did you put in, with the wrong oil, you could destroy the transmission...
Oct 19, 2010 at 8:35 PM
