1993 Chrysler Le Baron IGNITION
1993 CHRYSLER LE BARON
120,000 MILES • 6 CYL • FWD • AUTOMATIC
WTJONESSSS
ENGINE WON'T START.
NO JUCE TO THE SPARK PLUGS
NO JUCE TO THE COIL
Oct 6, 2010 at 5:11 AM
JDL
  • 16,098 POSTS
You might check for applicable mil codes? Primary voltage to coil comes from the asd relay. I'd check the circuits at the asd relay, also, look for an rpm signal that comes from the optical sensor in the distributor for 3.0L engine.
Oct 6, 2010 at 6:28 AM
