1993 Chrysler Le Baron Idle control off causing bad timing?
127,000 MILES • 6 CYL • FWD • AUTOMATIC
MUSCLEHEAD1063
The car idles rough. After it warms up it begins to lope between .75 and 1 rpm and starts a small knock but that gaoes away with a little gas. The rpms will also drop to .5 when shifting from drve to park now amd then. I have done a major tune up, replaced the fuel filter and the egr. Just dint know which way to go an this.
Thanks
Mar 9, 2010 at 7:24 AM
  • 110,248 POSTS
Has the check engine light come on? It sounds like a problem with the idle air control valve. Also, have you checked for vacuum leaks?
Mar 11, 2010 at 2:05 AM
