We bought this car probably abouta year ago. When we got it we were told that there was an issue with the rear Driver's side window. It doesn't move at all. I tore apart the door panel and used a 12V test light on the switch and the switch does work in both directions. My next dilemma is how do I get to that back window motor, how do I test to see if it is bad, and how do I go about replacing it? We've got another Le Baron with the same issue also.
May 9, 2008 at 6:18 AM
