1993 Chrysler Le Baron
1993 CHRYSLER LE BARON
BIGPAT74
1993 Chrysler Le Baron 6 cyl Front Wheel Drive Automatic
why does the surpintine belt keep falling off the pulleys
Aug 29, 2009 at 9:55 AM
CH112063
  • 1,320 POSTS
The tensioner pullet is worn, the whole pulley system is not aligned correctly, or you have the wrong belt. In that order.
If your not sure, eyeball the pulleys for alignment, then put a Mopar tensioner, and new belt on. Anything else would be unusual materials constantly getting in the system.
Aug 30, 2009 at 7:42 AM
