Sounds like you should first change the thermostat, then if equipped with electronic fans, make sure they are coming on and staying on when the vehicle is warm.
Then test the water pump by holding upper radiator hose with gloves on while the vehicle is hot and running, you should feel pressure build up and when the hose is released water should rush past and you should be able to feel it. If not the pump is bad.
SPONSORED LINKS
Friday, April 18th, 2008 AT 8:08 PM
