1992 Chrysler Le Baron Left turn signal
1992 CHRYSLER LE BARON
83,000 MILES • 4 CYL • FWD • AUTOMATIC
WBBURKE2001
Left turn signal stays steady will not blink
Sep 15, 2010 at 6:41 PM
PLOPPYSATOR
  • 23 POSTS
There are 2 metal gray 30 Amp relais at the left side under the steering wheel, one of them is fot the left marker, replace them againts each other to check if it is the relais and if yes, replace it
Oct 20, 2010 at 2:38 AM
