Login
Join
Ask a Question
Questions by Vehicle
Repair Topics
Testing / Diagnostics
Repair & Service Guides
Symptoms
Warning Lights
Trouble Codes
How It Works
Videos
Login
Become a Member
Home
Chrysler
Le Baron
Exterior Light
Turn Signal
1992 Chrysler Le Baron Left turn signal
1992 CHRYSLER LE BARON
83,000 MILES • 4 CYL • FWD • AUTOMATIC
WBBURKE2001
MEMBER
Left turn signal stays steady will not blink
Sep 15, 2010 at 11:41 AM
PLOPPYSATOR
MEMBER
There are 2 metal gray 30 Amp relais at the left side under the steering wheel, one of them is fot the left marker, replace them againts each other to check if it is the relais and if yes, replace it
Oct 19, 2010 at 7:38 PM
Add image or video
Ask a new question
Engine won't start
Engine stalls while driving
