1992 Chrysler Le Baron Engine running too cold
80,000 MILES • 6 CYL • FWD • AUTOMATIC
AMANDA KENNEDY
We have replaced the thermostat but the engine remains at 1/3 running temperature. Blocked off front of rad and still remains below normal operating temperature. Effects transmission downshifting from overdrive to drive.
Dec 27, 2008 at 3:59 AM
  • 110,248 POSTS
Hi:
If the t-stat is good, the engine should heat. First, rent a thermometer from a parts store that can be used in the radiator. With the engine cold, open the radator and place it in the radiator coolant and start the car. Allow it to run. See if the temp on the thermometer goes to around 195 degrees. If it does, try replacing the temp sending unit.
Let me know what you find.
Mar 17, 2009 at 3:29 AM
