1992 Chrysler Le Baron Engine overheating & no heat int
1992 CHRYSLER LE BARON
198,000 MILES • 4 CYL • FWD • AUTOMATIC
KRAMBO
My LeBaron has been overheating off & on for a while. Right now it has begun to NOT produce heat for the inside of the car and the coolant overflow tank appears to be overflowing thru the overflow vent on the side! Could this be caused by a faulty thermostat?
Another quirk: sometimes when I am driving at slow speeds for extended time periods and the engine begins to overheat I can force the engine RPMs to over 3grand and the temp will drop back to within normal range. What might be the cause of this?
Thanx in advance.....
Krambo
Feb 17, 2009 at 2:05 AM
DOCFIXIT
  • 18,828 POSTS
Thermostae good place to start also check cooling fan operation.
Feb 17, 2009 at 5:02 AM
