Electrical problem
1992 Chrysler Le Baron 6 cyl Two Wheel Drive 39000 miles
Battery goes dead after 4 days sitting. New alternator did not help, which rules out bad diode.. All electrical things work. Test light between negative battery post and disconnected groud cable glows brightly until interior lamps fuse under dash is pulled. With this fuse out battery stays up.
Trouble code (ignition switch turned off/on three times) reads 337. Mechanic using
Alldata Online finds no such code. does anyone know what code 337 means?
Jan 12, 2010 at 12:24 PM
