1992 Chrysler Le Baron Coolant Temp gauge & cooling fan
56,617 MILES • 6 CYL • FWD • AUTOMATIC
IMAVEGASNATIVE
I am having problems with the electronic cooling fan. The fan motor itself works, however the cooling fan does not come on and the coolant temp gauge does not move even with the vehicle running. Is the temp gauge and cooling fan relay controlled as one, or are these seperate issues. Thank you in advance for time!
Jul 17, 2010 at 1:23 PM
PLOPPYSATOR
  • 23 POSTS
It sounds like a defective cooler fan relais, but you might also check the temperature sensor, if a replacement of the relais does not solve the problem
Oct 19, 2010 at 8:10 PM
