1992 Chrysler Le Baron Check Engine Light
1992 CHRYSLER LE BARON
JUDYG
Engine Performance problem
1992 Chrysler Le Baron 6 cyl Front Wheel Drive Automatic
How can i check the code for the check engine light without using a meter? I hear there is a way to make the check engine light blink the number of the code out and then i can look it up. I have the codes in my chiltons book, just not a way to check the blinks.
updated 4/11/10
Good Evening,
Thank you for the response it was very helpful. I have another question. Where is the intake air temperature sensor located on the intake? The chrysler dealer couldnt even tell me and it is not on the diagrams in my chiltons book.
Apr 7, 2010 at 1:18 PM
DOCFIXIT
  • 18,828 POSTS
Turn key on do not start off, on off on MIL will flash code so flash, flash 4 sec pause flash, flash, flash = 23 a long pause between codes.
Apr 8, 2010 at 7:17 AM
