1992 Chrysler Le Baron car over heated and motor shut off o
1992 CHRYSLER LE BARON
106,000 MILES • 6 CYL • 2WD • AUTOMATIC
JEREMY MOSES
i was wound ering what i could do to fix my 1992 chrysler lebaron because my car over heated and this time the motor shut off on me and now ity wont start back up. what could be the problem be?
Dec 21, 2007 at 11:28 PM
BLACKOP555
  • 10,386 POSTS
first you will have to check for spark at the #1 cylinder, it should be bright, blue and well defined.
next you should check for fuel at the fuel rail.
Dec 22, 2007 at 12:18 AM
JEREMY MOSES
ok so if thoes are all fine then what do i do after that to figure it out what is the problem with the car
Dec 22, 2007 at 12:32 AM
BLACKOP555
  • 10,386 POSTS
if those are all fine you will have to check for compression on all the cylinders and check for injector pulse.
also you may want to check to make sure the car did not jump time.
Dec 22, 2007 at 12:39 AM
JEREMY MOSES
ok i will check all of thoes thing when i get out of work
Dec 22, 2007 at 12:41 AM
