Brakes problem
1992 Chrysler Le Baron 6 cyl All Wheel Drive Automatic
I just replaced the front brake pads, and now the brake pedal will not pump up while the engine is running. The pedal goes to the floor, but with the engine off, the pedal will get firm. I've checked for fluid leaks everywhere with none found
May 25, 2009 at 7:26 AM
