1991 Chrysler Le Baron Hubcap
1991 CHRYSLER LE BARON
DR. THOMAS
1991 Chrysler Le Baron 6 cyl Front Wheel Drive Automatic
i have a problem that need a hand with, how do you pull that type of hubcap off the rim to change the tire? Any help would be great
Sep 20, 2010 at 11:58 AM
BLUELIGHTNIN6
  • 16,542 POSTS
the hub cap clips on, there should be a center cap to it that also just clips on. use flat blade tool to pry center cap off and then the hub cap off.
Sep 20, 2010 at 12:19 PM
