1991 Chrysler Le Baron Drivers window glass
1991 CHRYSLER LE BARON
160,000 MILES • 6 CYL • 2WD • AUTOMATIC
TRAVELAGAIN
I need to replace the track on the bottom of the drivers door glass. It appears that it is necessary to remove the glass to get to the screws that hold the track. How do you remove the window glass? This is a 4 door sedan.
Nov 21, 2008 at 2:39 AM
  • 110,244 POSTS
Have you removed the door panel? If so, check along the track. Look for a nut that places tension on the glass.
Let me know if you find it.
Mar 17, 2009 at 3:36 AM
