1991 Chrysler Le Baron
SLAPPY369
Interior problem
1991 Chrysler Le Baron 6 cyl Front Wheel Drive Automatic
I bought a replacement door lamb switch and i am having problems figuring out how to get the old one out.
Mar 14, 2010 at 7:49 AM
CH112063
  • 1,320 POSTS
You'll need a deep 7/16ths socket or an 11mm works also and a ratchet. It just unscrews, use 6 point sockets, better with a 1/4 inch drive but 3/8ths drive ratchet will work. Just remove, switch the wire over and screw it back in. It self adjusts on the first closing of the door. Some have a screw or two holding them in(plastic type). ok
Mar 20, 2010 at 3:54 PM
